WiFi Roaming
Has anyone managed to get WiFi roaming to work with AP6210 or similar WiFi module? Specifically, I am trying to get this to work on the NanoPi using Debian Jessie. However, if you have WiFi roaming working on any NanoPi variant using the AP6xxx WiFi/Bluetooth module I would like to compare notes.
Thanks,
davef
Got it working, one just needs to setup the files in /etc/network/interfaces and wpa_supplicant configuration correctly.
