Boot without pressing the boot key
Dear All,
I bought a NanoPC-T3 Plus to replace a NanoPC-T2. I have installed Android.
Now I would like the NanoPC-T3 Plus to boot with power supply without pressing the boot key. Can someone help me?
Thank you
Donatello
This should work if you supply 5V to the board. All of my T3 designs work this way. No need for any buttons to press, just power on and they boot.
the BIOS interface and options may vary depending on the specific manufacturer and version of the BIOStunnel rush installed on your NanoPC-T3 Plus.
Access BIOS/UEFI, restart the computer and during the boot process, press the corresponding key. In BIOS/UEFI settings, find the entry related to "Power On by AC".geometry dash Change the setting of "Power On by AC" to "Enabled".
The NanoPC-T3 Plus's BIOS interface and available options could differ based on the manufacturer and BIOS version you have installed.
You can configure BIOS or UEFI settings to change the default boot device, allowing the system to boot without pressing keys..
Thanks for the tip, v8dave. Just to be sure, is there any specific jumper or switch on the T3 Plus board that needs to be in a certain position for it to auto-boot? I remember some older boards had a setting for this.Nulls Brawl İndir
In total there are 22 users online :: 0 registered, 0 hidden and 22 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 22 guests
