How to debug operate the board via serial terminal
Good afternoom everyone, how are you?. I'm looking for how to operate the board via serial terminal because otherwise I need a screen and a keyboard and that is not possible for me every time, I mean:
1) As soon as I start the board it send notifications through the serial port?.
2) The commands that I use are the same as if I'm using the linux console.
3) Its possible to do a ssh session through the serial port?.
I need all the help here so thanks in advance for all the help you can give me.
:D :D :D :D
1 & 2 = YES
3 = NO :)
when the board does start it will - like any Pi Board - send startup-messages (boot) to the serial port (ttyS0).
After the boot-messages you will get a login-prompt.
After login you could use the normal commands like on a SSH-session, but because you are DIRECTLY connected to the system there is no secure-layer between you and the board like on a SSH-session (you only have to login via the right user/password combination)
guidol wrote:
1 & 2 = YES
3 = NO :)
Hi Guidol! Thank you so much for your answer. Now I have another question, How can I change the debug port to the usb otg port?. As you can see, I'm kind of new with linux.
Thanks in advance for your help.
VALERYRAMIREZ wrote:
that wouldnt be easy :(
On a Raspberry Pi you could use the otg-port as normal network port like eth0 (not serial).
You could appy a network-adress and ssh into that port:
http://www.circuitbasics.com/raspberry- ... et-gadget/
https://raspberrypi.stackexchange.com/q ... -tethering
BUT I dont know how to do this on a NanoPi because there is no config.txt to configure - and I think anyboy would say that has to be compiled into the kernel :-(
Why would you use the otg-port and not the normal debug port? Or any other serial port (via gpio-pins) or another serial-port via a USB2serial converter?
Hi Guidol!
The reason is because right now I don't have the usb to TTL converter with, I will build it with a max232 SMD that I have and a usb to RS232 converter but to the weekend, the other and most important reason is comfort, If its possible to communicate through the same port where I charge the device, like the pi, then is much better.
In the other hand, this subject is treated in the following post but I have to research more to understand what is there, in that post
MrUnreliable
talks about boot/boot.cmd:
http://www.friendlyarm.com/Forum/viewtopic.php?f=47&t=683&p=2268&hilit=debug#p2268
