How to record sound with ffmpeg
Hi all.
I have a problem with sound if ffmpeg on NanoPi NEO Air with ubuntu_core_3.4_20170220
I install the eflasher_ubuntutu_core_3.4_20170220 on NanoPi NEO Air and want to record audio and video from camera and microphone with ffmpeg.
I found how to record video in ffmpeg, but I didn't find how to record audio without alsa in ffmpeg.
How can I record audio and video without alsa in ffmpeg?
I tried to recompile ffmpeg from https://github.com/stulluk/FFmpeg-Cedrus with patch from https://github.com/uboborov/ffmpeg_h264_H3 and I found that library libasound-dev had absent. After install libasound-dev and ./configre ffmpeg and saw that I had an alsa an input device.
May be guys that support ubuntu_core with kernel 3.4 will make a new distributiv with alsa in ffmpeg!
Now I have a new problem with ubuntu_core_4.11_20170531 on NanoPi NEO Air.
After connect camera CAM500B to the board and load ubuntu_core_4.11 I don't see device video0.
Now the mainline kernel has already support ffmpeg, but now don't support DVP driver.
thank you!
