NanoPI R1 Routeur
I testing NaniPI R1 in routeur and AP Wifi, inposible work !!!!
I have install FriendlyElec xenial 16.04, and config hostapd and dnsmasq, after start dnsmasq
root@NanoPi-R1:~# /etc/init.d/dnsmasq status
● dnsmasq.service - dnsmasq - A lightweight DHCP and caching DNS server
   Loaded: loaded (/lib/systemd/system/dnsmasq.service; enabled; vendor preset: enabled)
  Drop-In: /run/systemd/generator/dnsmasq.service.d
           └─50-dnsmasq-$named.conf, 50-insserv.conf-$named.conf
   Active: failed (Result: exit-code) since Sun 2020-03-22 17:30:07 UTC; 1min 59s ago
  Process: 672 ExecStart=/etc/init.d/dnsmasq systemd-exec (code=exited, status=2)
  Process: 619 ExecStartPre=/usr/sbin/dnsmasq --test (code=exited, status=0/SUCCESS)
Mar 22 17:30:06 NanoPi-R1 systemd[1]: Starting dnsmasq - A lightweight DHCP and caching DNS server...
Mar 22 17:30:06 NanoPi-R1 dnsmasq[619]: dnsmasq: syntax check OK.
Mar 22 17:30:07 NanoPi-R1 dnsmasq[672]: dnsmasq: failed to create listening socket for 192.168.10.1: Cannot assign requested address
Mar 22 17:30:07 NanoPi-R1 systemd[1]: dnsmasq.service: Control process exited, code=exited status=2
Mar 22 17:30:07 NanoPi-R1 systemd[1]: Failed to start dnsmasq - A lightweight DHCP and caching DNS server.
Mar 22 17:30:07 NanoPi-R1 systemd[1]: dnsmasq.service: Unit entered failed state.
Mar 22 17:30:07 NanoPi-R1 systemd[1]: dnsmasq.service: Failed with result 'exit-code'.
No doc found !!!!
Not possible to configure the NanoPI R1 as a router and WiFi access point ??
Do you have an idea ?
Greeting,
C.
No doc found !!!!
Greeting,
C.
Perhaps try this: https://www.armbian.com/nanopi-r1/
Instructions:
phpBB [video]
In total there are 24 users online :: 0 registered, 0 hidden and 24 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 24 guests
