Which M.2 SSD are known to be working in NanoPC-t4 ?
Dear all ,
I would suggest everyone to share his experience with M.2 SSD recognizable by NanoPC-T4 .
From internet I found that these models should work:
LITEON T10 120GB SSD
Samsung MZ-V7E2T0BW SSD 970 EVO
From my personal experience: "shorty" Toshiba KBG30ZMS256GA is not recognized by T4.
We are going to buy the most affordable SSD for that board and I want to avoid mistakes.
Believe that this info could be useful for all .
Thanks !
Dmitry
dmitryz wrote:
Dear all ,
Thanks !
Dmitry
On which kernel? There has been some troubles regarding PCI in the latest development kernel.
igorp wrote:
dmitryz wrote:
Dear all ,
Thanks !
Dmitry
kernel 4.4.154
dmitryz wrote:
igorp wrote:
dmitryz wrote:
Dear all ,
Thanks !
Dmitry
kernel 4.4.154
That should be fine. BTW. Samsung 960 PRO 512GB is also working fine.
Just want to add some details . I switched to Armbian and still no luck with my Toshiba . But could it be a problem of board ?
Here is what i see in dmesg regarding PCI with NVMe SSD plugged in:
# dmesg | grep -i pci
PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000 ( 16 M B)
[ 0.119383] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee2 0000 domain created
[ 1.540416] PCI: CLS 0 bytes, default 64
[ 1.948302] phy phy-pcie-phy.5: Looking up phy-supply from device tree
[ 1.948312] phy phy-pcie-phy.5: Looking up phy-supply property in node /pcie- phy failed
[ 1.950471] rockchip-pcie f8000000.pcie: GPIO lookup for consumer ep
[ 1.950482] rockchip-pcie f8000000.pcie: using device tree for GPIO lookup
[ 1.950510] of_get_named_gpiod_flags: parsed 'ep-gpios' property of node '/pc ie@f8000000[0]' - status (0)
[ 1.950757] rockchip-pcie f8000000.pcie: Looking up vpcie3v3-supply from devi ce tree
[ 1.950858] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply from devi ce tree
[ 1.950870] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply property in node /pcie@f8000000 failed
[ 1.950884] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 1.950892] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply from devi ce tree
[ 1.950901] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply property in node /pcie@f8000000 failed
[ 1.950913] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 1.971648] rockchip-pcie f8000000.pcie: invalid power supply
[ 2.471703] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 2.471905] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 2.593787] ehci-pci: EHCI PCI platform driver
# uname -a
Linux boise 4.4.174-rk3399 #31 SMP Sun Feb 10 00:37:23 CET 2019 aarch64 aarch64 aarch64 GNU/Linux
successfully tested wih following M.2 SSDs
Samsung 970 EVO
Kingston SA1000M8
Intel SSDPEKKW128G801
So, it's definitely a problem of Toshiba KBG30ZMS256GA .
All NVME protocol SSDs should be available, SATA protocol will not work.
__________________________________________________
Bluestacks Kodi Lucky Patcher
I am using an "addlink S70 512GB NVMe PCIe" on my T4, In Android v8.1 Oreo, But i am only getting approx 500R/450W not the spec 3000R/2000W
John.
Hello all! Has anyone tested wih Intel 660p Series recognizable by NanoPC-T4.
We are going to buy M.2 SSD Intel 660p Series 2Tb, SSDPEKNW020T8X1.
Please share his experience with M.2 Intel & T4
Thanks.
