Nanopi-R4S - OpenWRT - How to use RTC ?
Posted: Thu Aug 29, 2024 7:53 pm
by Sergio
How can I use RTCWake to put the system into Suspend Mode and set a Wake Time ?
I could not fin any cli command to do this.
Any tips or suggestions would be appreciated.
Re: Nanopi-R4S - OpenWRT - How to use RTC ?
Posted: Thu Jul 03, 2025 4:39 am
by sandragin
You can specify the wake time in seconds from the current time or in a specific timestamp.
Example Command
To suspend the system for a specific duration (e.g., 1 hour) and wake it up, you can use:
sudo rtcwake -m suspend -l -s 3600
This command will suspend the system for 3600 seconds (1 hour).
Example with Specific Time
If you want to set a specific wake-up time, you can convert your desired wake time into a Unix timestamp. For example:
sudo rtcwake -m suspend -l -t $(date +%s -d '2025-07-03 10:00:00')
Replace 2025-07-03 10:00:00 with your desired date and time.
Posted: Mon Aug 18, 2025 7:17 am
by ustycelebra
:o :o The -s option is great for quick tests, but I think I’ll stick with the -t timestamp method for daily scheduling. I’ve had trouble before when trying to calculate the exact duration, so having an absolute time is easier for me.
