Armbian for R2S and Neo3
Armbian 20.02.4 Buster ttyGS0
nanopi-r2s login: root
Password:
Last login: Thu Apr  9 06:09:43 UTC 2020 from 10.0.10.50 on pts/1
 _   _                         _   ____  ____  ____
| \ | | __ _ _ __   ___  _ __ (_) |  _ \|___ \/ ___|
|  \| |/ _` | '_ \ / _ \| '_ \| | | |_) | __) \___ \
| |\  | (_| | | | | (_) | |_) | | |  _ < / __/ ___) |
|_| \_|\__,_|_| |_|\___/| .__/|_| |_| \_\_____|____/
                        |_|
Welcome to Armbian buster with Linux 5.4.28-rockchip64
No end-user support: work in progress
System load:   2.41 0.64 0.22   Up time:       1 min
Memory usage:  27 % of 471MB    IP:            10.0.30.132 169.254.10.105 10.0.20.215
CPU temp:      70°C
Usage of /:    4% of 58G
[ General system configuration (beta): armbian-config ]
- login console is enabled also on mUSB connector
- known problem: reboot sometimes doesn’t bring the device back.
- network devices are not managed by Network manager. Configure via /etc/network/interfaces
- comes in Bionic, Buster, Bullseye and Stretch
- can be build from sources https://github.com/armbian/build
- supported: Docker, Wireguard, ...
- Iperf3 on lan: 937 - 910Mbits/s and wan: 879 - 831Mbits/s
- getting started
https://www.armbian.com/nanopi-r2s/
Added Ubuntu Focal variant and a few other fixes.
v20.08
- kernel 5.7.y
- improved 1st login with location based semi automated language / locales detection
- Ubuntu Bionic/Focal or Debian Buster/Bullseye
- compiled with GCC 9.2
- updated wireless drivers
- upgraded download infrastructure (still a bit in works)
Download:
https://www.armbian.com/download/?tx_maker=friendlyelec
How to build from sources?
git clone https://github.com/armbian/build
cd build
./compile.sh
https://twitter.com/armbian/status/1296687681037107200
I just bought 2 neo3 and started with Armbian and the MAC address is the same.
But using the official image is a different MAC address.How can I use Armbian so that neo3 has the correct unique MAC address?
Enjoy today's #armbian bugfix and features update! https://docs.armbian.com/Release_Changelog/
Update which includes some nic driver stability fixes on R2S
https://www.armbian.com/newsflash/armbi ... ix-update/
Will you be able to add USB 2.0 pins on Neo3 functionality to turn on via armbian-config?
Tried to build kernel myself, but failed as a noob : (
Thanks for keeping us updated igorp!
