NEO3: excessive CPU/DRAM voltage?
I have a number of SBCs with the Rockchip 3328 SOC; now the NanoPi NEO3 too.
Oddly, the NanoPi NEO3 is the most power hungry and the hottest of the bunch, despite running at the same frequency (1.3 GHz).
I'm running stock FriendlyCore, with the latest updates.
This suggests that the CPU voltage (and probably DRAM voltage) are set a bit too high.
Is there a way to try lowering the voltages?
For example, with the Raspberry Pi you can "play" with CPU voltage by adjusting a parameter in /boot/config.txt
Thanks!
Thanks!
Have you checked with more polished OS?
https://www.armbian.com/nanopineo3/
In total there are 29 users online :: 1 registered, 0 hidden and 28 guests (based on users active over the past 5 minutes)
Users browsing this forum: Google Adsense [Bot] and 28 guests
