Replece H3 BGA
H3 burned out!
Hello I'm having a problem on a nanoPi -M1 card
This board is with H3 damaged, would you like to know the following?
If I replace the H3 alwinner with a new H3 BGA, purchased directly from an Alwinner vendor, would it be necessary to have some firmware for this new processor to work on the nanoPi-M1 card?
Or would simple replacement suffice to function?
Can you answer me, please? I will be grateful!
Sorry in English because it is not my native language.
Thank you!
joctal wrote:
H3 burned out!
Thank you!
You can replace it with a new H3 chip, no firmware inside it.
Good luck
-- Mindee
