duo2 IOT-BOX GPIO command to turn on GSM
it seems that the GSM is always off by default
from the default sim800c-test.py
we can find that the GSM_PWR is pin 11 and LED is pin 9
what command do i use from WiringNP to turn it on ?
i tried
gpio MODE 11 IN
gpio MODE 9 OUT
but nothing change when i use gpio readall to check
what GPIO command should i use ?
found the answer
to turn on the modem use sudo/root
gpio mode 16 out
gpio write 16 1
In total there are 6 users online :: 0 registered, 0 hidden and 6 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 6 guests
