How install openvpn?
I install the application and configure this, but it's fail because TUN interface.
sudo modprobe tun
modprobe: FATAL: Module tun not found in directory /lib/modules/4.4.138
Some help?
sudo modprobe tun
Some help?
Works on Armbian out of the box:
https://github.com/armbian/build/blob/m ... nfig#L1782
Download:
https://www.armbian.com/download/?tx_soc=rk3399
igorp wrote:
sudo modprobe tun
Some help?
Download:
Some possibility to load the image from type-c (with rockchip application)?
I have friendlycore now.. no way to add TUN to it? :?
Never tried that but it is possible that it will work. You can install it to the eMMC with our app but you need to start with SD card ... Here https://www.youtube.com/watch?v=C0Bl0yjESLo you can check boot process and quick app run from eMMC/NVMe
Too complicated. In case you will find a need to add something else in the future, with Armbian this is super easy.
Building a new kernel is super easy (see the wiki)
Just add the modules you need, build your kernel and load it. Install your modules and done.
