NanoPC-T2 does not get IP after boot on ubuntu
I have nanopc-T2, It does not get IP with Ethernet when I connect it to my host(PC with DHCP IP). I install ubuntu with qt core, this is wiki page said for Ip:"If a board is connected to a network via Ethernet before it is powered on it will automatically obtain an IP with DHCP activated after it is powered up." I do that but again write on LCD : IP:0.0.0.0
how can I solve it?
leemccarthyn wrote:
I have nanopc-T2, It does not get IP with Ethernet when I connect it to my host(PC with DHCP IP). I install ubuntu with qt core, this is wiki page said for Ip: "If a board is connected to a network via Ethernet before it is powered on it will automatically obtain an IP with DHCP activated after it is powered up." I do that but again write on LCD : IP:0.0.0.0
how can I solve it?
Those images and upgrades were tested many many times, because support is expensive and "you" forget to cover that cost. I test this particular case 3x:
- updating installation which was already on eMMC
- one old version: Armbian_5.75_Nanopct4_Debian_stretch_default_4.4.174.7z
- the same as you did: Armbian_5.91_Nanopct4_Debian_buster_default_4.4.179.7z http://ix.io/1TCV
... and I can't reproduce. How can we explain this case?
Have you read this: https://docs.armbian.com/User-Guide_Getting-Started/?
Do you use decent/quality SD card?
Proper SD card writing method?
Official PSU?
I think this armbian quoted message will help you to understand this thing.
