SSID not Visible
I flash image rk3568-eflasher-friendlywrt-21.02-20240314.img to eMMC on the R5C.
I connect an ethernet cable from my router to the WAN port of the R5C.
I connect an ethernet cable from the LAN port of the R5C to my laptop.
I reboot the R5C. My laptop acquires an internet connection. So the above setup seems to be working so far. I am able to ssh in from the laptop to the R5C. Now I try to enable wifi on the R5C but I cannot get it to work.
I point my browser at http://192.168.2.1 and I authenticate. I go to Network / Wireless. I see an entry for SSID, I click Edit. Under Advanced Settings, I change the country code from CN (China) to my country, BE (Belgium). I click Save, Save & Apply. Then I click Enable. Back on the main page it displays the error Wireless is not associated. I reboot the device, the error is gone:
The SSID is not visible, neither from my laptop nor from my cell phone. Under Operating Frequency, Channel is set to Auto. I saw a post online somewhere saying that this is bad. I try various other values for Channel, e.g. 165 (5825 Mhz). This does not fix the problem.
I have attempted to tinker with many of the other values in the menus. No matter what I do, the SSID never becomes visible, neither to my laptop nor to my cellphone. I would be grateful for some help.
Here is the output of iw list:
root@FriendlyWrt:~# iw list
Wiphy phy0
   wiphy index: 0
   max # scan SSIDs: 9
   max scan IEs length: 2304 bytes
   max # sched scan SSIDs: 0
   max # match sets: 0
   Retry short limit: 7
   Retry long limit: 4
   Coverage class: 0 (up to 0m)
   Device supports AP-side u-APSD.
   Available Antennas: TX 0 RX 0
   Supported interface modes:
       * IBSS
       * managed
       * AP
       * P2P-client
       * P2P-GO
   Band 1:
      Capabilities: 0x1963
         RX LDPC
         HT20/HT40
         Static SM Power Save
         RX HT20 SGI
         RX HT40 SGI
         RX STBC 1-stream
         Max AMSDU length: 7935 bytes
         DSSS/CCK HT40
      Maximum RX AMPDU length 65535 bytes (exponent: 0x003)
      Minimum RX AMPDU time spacing: 16 usec (0x07)
      HT Max RX data rate: 300 Mbps
      HT TX/RX MCS rate indexes supported: 0-15
      Frequencies:
         * 2412 MHz [1] (20.0 dBm)
         * 2417 MHz [2] (20.0 dBm)
         * 2422 MHz [3] (20.0 dBm)
         * 2427 MHz [4] (20.0 dBm)
         * 2432 MHz [5] (20.0 dBm)
         * 2437 MHz [6] (20.0 dBm)
         * 2442 MHz [7] (20.0 dBm)
         * 2447 MHz [8] (20.0 dBm)
         * 2452 MHz [9] (20.0 dBm)
         * 2457 MHz [10] (20.0 dBm)
         * 2462 MHz [11] (20.0 dBm)
         * 2467 MHz [12] (20.0 dBm) (no IR)
         * 2472 MHz [13] (20.0 dBm) (no IR)
         * 2484 MHz [14] (disabled)
   Band 2:
      Capabilities: 0x863
         RX LDPC
         HT20/HT40
         RX HT20 SGI
         RX HT40 SGI
         No RX STBC
         No DSSS/CCK HT40
      VHT Capabilities (0x03d071b2):
         Max MPDU length: 11454
         Supported Channel Width: neither 160 nor 80+80
         RX LDPC
         short GI (80 MHz)
         TX STBC
         SU Beamformee
         MU Beamformee
         +HTC-VHT
      VHT RX MCS set:
         1 streams: MCS 0-9
         2 streams: MCS 0-9
         3 streams: not supported
         4 streams: not supported
         5 streams: not supported
         6 streams: not supported
         7 streams: not supported
         8 streams: not supported
      VHT RX highest supported: 867 Mbps
      VHT TX MCS set:
         1 streams: MCS 0-9
         2 streams: MCS 0-9
      VHT TX highest supported: 867 Mbps
      Frequencies:
         * 5180 MHz [36] (20.0 dBm) (no IR)
         * 5200 MHz [40] (20.0 dBm) (no IR)
         * 5220 MHz [44] (20.0 dBm) (no IR)
         * 5240 MHz [48] (20.0 dBm) (no IR)
         * 5260 MHz [52] (20.0 dBm) (no IR)
         * 5280 MHz [56] (20.0 dBm) (no IR)
         * 5300 MHz [60] (20.0 dBm) (no IR)
         * 5320 MHz [64] (20.0 dBm) (no IR)
         * 5500 MHz [100] (20.0 dBm) (no IR)
         * 5520 MHz [104] (20.0 dBm) (no IR)
         * 5540 MHz [108] (20.0 dBm) (no IR)
         * 5560 MHz [112] (20.0 dBm) (no IR)
         * 5580 MHz [116] (20.0 dBm) (no IR)
         * 5600 MHz [120] (20.0 dBm) (no IR)
         * 5620 MHz [124] (20.0 dBm) (no IR)
         * 5640 MHz [128] (20.0 dBm) (no IR)
         * 5660 MHz [132] (20.0 dBm) (no IR)
         * 5680 MHz [136] (20.0 dBm) (no IR)
         * 5700 MHz [140] (20.0 dBm) (no IR)
         * 5720 MHz [144] (20.0 dBm) (no IR)
         * 5745 MHz [149] (20.0 dBm) (no IR)
         * 5765 MHz [153] (20.0 dBm) (no IR)
         * 5785 MHz [157] (20.0 dBm) (no IR)
         * 5805 MHz [161] (20.0 dBm) (no IR)
         * 5825 MHz [165] (20.0 dBm) (no IR)
         * 5845 MHz [169] (disabled)
         * 5865 MHz [173] (disabled)
         * 5885 MHz [177] (disabled)
   valid interface combinations:
       * #{ managed, P2P-client } <= 2, #{ AP, P2P-GO } <= 1,
         total <= 2, #channels <= 1
   max # scan plans: 1
   max scan plan interval: -1
   max scan plan iterations: 0
   Supported extended features:
Have you fixed that problem yet?. Please show me how to fix it.
Van has not found a suitable solution. The real problem is to understand more about SSID.
