docker stats
When I run `docker stats` I get:
WARNING: No memory limit support
WARNING: No swap limit support
WARNING: No cpu cfs quota support
WARNING: No cpu cfs period support
WARNING: No cpu shares support
WARNING: No cpuset support
WARNING: No io.weight support
WARNING: No io.weight (per device) support
WARNING: No io.max (rbps) support
WARNING: No io.max (wbps) support
WARNING: No io.max (riops) support
WARNING: No io.max (wiops) support
My bootloader looks like...
root=/dev/nvme0n1p8 rw rootfstype=ext4 data=/dev/nvme0n1p9 consoleblank=0 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
Is there some magic way to make it work?
I want to see/limit the cpu and mem usage of my containers.
This is working after upgrading to rk3568-sd-friendlywrt-23.05-docker-20240703.img
Maybe that's just a coincidence, but whatever, it's working.
It's back... damn.
