Problems winth Netflix on NanoPC-T3
Good evening!
I installed Android on the eMMC flash memory of my NanoPC-T3, everything works fine, minus the Netflix app.
I can install the app, log in and even access the movie catalog, but when I click play in the movie, a 13001 error message appears and the app closes.
I have already accessed the Netflix site to solve the problem and the only solution is to clear the cache or reinstall the app, but it still does not work.
Does anyone have a solution to this problem?
Note: I already did tests running on Android from the SD card and it still does not work.
Thank you,
Romsonline
romsonline wrote:
Good evening!
Thank you,
Romsonline
We tested it too, got the same error. We guess the reason is the lack of DRM driver, it's about copyright. We have no way to solve it for now, please understand .
Thank you
Mindee
Mindee wrote:
romsonline wrote:
Good evening!
Thank you,
Romsonline
Thank you
Mindee
Good Evening!
Tankyou for your reply.
Do you know if Friendlyarm can make a path to fix this problem?
Thank you again.
Romsonline
romsonline wrote:
Mindee wrote:
romsonline wrote:
Good evening!
Thank you,
Romsonline
Thank you
Mindee
Good Evening!
Thank you again.
Romsonline
This SoC is from Nexell company, you can try to ask them.
And we are asking them for this problem too. Not so fast to get solution.
Thank you
-- Mindee
