Library not working in Android 5.1
Hello everyone, I am working with the NanoPC T2 and I have a problem when I am using the serial ports and also the GPIO ports, this only happens only with Android 5.1, since with Android 4.4 the same program works correctly, so I suppose there is Some kind of problem in the library installed in this Rom.
I have updated to the last version released by FriendlyArm, so I request to correct this problem to be able to use this Rom.
Best Regards
Hi
Please describe your problem in detail.
I developed an app, which uses the serial port and works properly on Android 4.4 (Friendlyarm), but when I install the same app in the version of Android 5.1 (Friendlyarm) is not working. The error occurs when executing the openserialport method, which returns the value -1.
In total there are 16 users online :: 1 registered, 0 hidden and 15 guests (based on users active over the past 5 minutes)
Users browsing this forum: Google Adsense [Bot] and 15 guests
